Screen tearing & "Fake inputs" caused by EMI solved.
Eonds
EMI is real and it has very real and damaging affects on performance. I've always had random screen tearing and that's because I've always had my fans at basically full speed. So my friend comes to me and says hey I have the same problem blah blah blah. So I do everything I can for his pc but nothing worked (some things improved symptoms). He had a fan set on top of GPU running at full speed to cool his ram. I remembered this and I told him to unplug it & the screen tearing instantly went away... The take away from this is to stop using hard drives, be careful using fans especially at full speed on top of sensitive components. Try reducing the fan speed/unplugging it. Screen tearing would occur regardless of FPS, vsync or any sort of sync tech. This was 100% caused by strong interference.
assombrosso
Re: Screen tearing & "Fake inputs" caused by EMI solved.
One of the things I tried was completely disabling all fans and it hasn’t worked
internetexplorer4
sameassombrosso wrote: ↑26 Oct 2022, 20:44One of the things I tried was completely disabling all fans and it hasn’t worked
mago
mb it can explain the smoothness in the beginning then the lag come after
Ⓢк𝕀lŁ เ𝓢 ᵗⒺм𝕡σr𝐀𝐑Ⓨ, lά𝔾 I𝐬 F𝔬ʳ𝔢𝓿ᗴ𝔯
