1080p@60Hz and 1080p@50Hz issue on CRT monitor
nuninho1980
Post by nuninho1980 » 08 Nov 2022, 07:05
Hello.
I've new GPU Zotac GAMING GeForce RTX 4090 Trinity with DP-VGA adapter using. :D
We know: 1080p = Full HD. :)
I get left horizontal position/zoom issue on 1080p@50Hz and 1080p@60Hz running CRT monitor Sony E530 Multiscan 21" (and other various CRT monitors too) - see screenshot:
horiz position issue.JPG (54.82 KiB) Viewed 1894 times
--> What's(are) any correct manually number(s) (active pixels, pixels total...) for create new 1920x1080@50Hz and @60Hz for any correct position/zoom on custom resolution running NV Control Panel?
NOTE: 1920x1200@50Hz and 1920x1200@60Hz are fine. :)
RAM: 2x16GB DDR4@3600MHz
MB: MSI PRO Z690-A DDR4
GPU: Zotac RTX 4090 non-OC <3 :D
HDD: SATA 1TB
PSU: AEROCOOL 1kW 80+ Gold
Disly: ViewSonic XG2431 23.8" NEW! :mrgreen:
ToastyX
Re: 1080p@60Hz and 1080p@50Hz issue on CRT monitor
Post by ToastyX » 09 Nov 2022, 17:18
For CRT monitors, you should use CVT or GTF standard (padrão).
nuninho1980
Post by nuninho1980 » 10 Nov 2022, 06:36
ToastyX wrote:
09 Nov 2022, 17:18
I choose GTF for 1920x1080@60Hz and this can be fine! Thank much you! :)
HDD: SATA 1TB
