Can you disable blur reduction? [yes, you can]
MCzero1
If i bought a xl2411z with 1v firmware witch has artifacting can i disable blur reduction and will it fix articacting?
Q83Ia7ta
Re: Can you disable blur reduction?
You can easily disable BenQ Blur Reduction. By default this monitor option (by OSD) is disabled. This bug (artifacting like you said) is only when BenQ Blur Reduction is ON.MCzero1 wrote:If i bought a xl2411z with 1v firmware witch has artifacting can i disable blur reduction and will it fix articacting?
