Can you disable blur reduction? [yes, you can]
Posted: 06 Jul 2014, 08:20
If i bought a xl2411z with 1v firmware witch has artifacting can i disable blur reduction and will it fix articacting?
Who you gonna call? The Blur Busters! For Everything Better Than 60Hz™
https://forums.blurbusters.com/
You can easily disable BenQ Blur Reduction. By default this monitor option (by OSD) is disabled. This bug (artifacting like you said) is only when BenQ Blur Reduction is ON.MCzero1 wrote:If i bought a xl2411z with 1v firmware witch has artifacting can i disable blur reduction and will it fix articacting?
