I'm very close to pulling the trigger on the AOC monitor available later this month.
I have a few little queries that i'm trying to find out first though, and this forum seems the most knowledgeable on GSync so far.
1) Is it possible to Downsample AND GSync at the same time ?
2) Can the common shader injectors, like SweetFX, eFX, SMAA injectors be used at the same time as gsync?
The reason I ask is that in many of my games I rely on downsampling and use of these injectors for IQ reasons.
My current monitor is a 22" BenQ @1920x1080p 60hz, but
I use gpu downsampling (Gtx 780) upto 3168 x 1782 60hz in quite a few games and I really dont want to lose this ability.
I just dont know how it would work to downsample and use gsync at the same time?
As gsync alters the refresh rate, if you have a downsample resolution that works at 60hz, it may not work at 144hz ???
Or am I missing the point here
Hope somebody can help !!
