Page 1 of 7
This fixes the electrical input lag
Posted: 12 Dec 2022, 12:03
by Skeezv
This thing fixes the input lag, a few people have already helped in the Russlan group where there are 300+ people. Toroidal balanced isolation transformer
https://aliexpress.ru/item/400034986321 ... b7340abb90
Re: This fixes the electrical input lag
Posted: 12 Dec 2022, 12:11
by texre
Skeezv wrote:
12 Dec 2022, 12:03
Can we get some clips
Posted: 12 Dec 2022, 12:21
by Skeezv
Posted: 12 Dec 2022, 12:54
by dervu
Don't be so fast. To be sure, you need months of PC working as expected.
However, I can confirm that it works as fixed. :mrgreen:
Posted: 12 Dec 2022, 13:00
by texre
dervu wrote:
12 Dec 2022, 12:54
You have one ? And it works for you? I’ve spent so much money trying to fix this problem don’t wanna waste more money trying to Play on grid
Posted: 12 Dec 2022, 13:06
by dervu
texre wrote:
12 Dec 2022, 13:00
dervu wrote:
12 Dec 2022, 12:54
Yes, I have it for very short time. Not the same one as OP, but from another reputable manufacturer.
If you do not want to risk money, don't. Just wait for long term confirmation, but people are impatient...
Posted: 12 Dec 2022, 13:08
by texre
I’ve seen you in the forms a lot and have talked to you before so I do believe you
Posted: 12 Dec 2022, 13:35
by kriegsnake
dervu wrote:
12 Dec 2022, 12:54
Can you please attach the link to the device you’ve got? Because the other one couldn’t be delivered to my location.
Posted: 12 Dec 2022, 14:10
by dervu
https://airlinktransformers.com/product ... -eucbs1500
Don't blame me, if you buy and it turns out bad after long time.
Time from buy to delivery at my place was around 2 weeks. Total cost with tax and delivery 560 eur + external RCD plug to be safe + power bar needs to have double pole switch - mine already had that (because current goes on both lines simultaneously). You can ask them to place RCD for additional fee.
Posted: 12 Dec 2022, 14:46
by akylen
Personally, I'm waiting for more time and feedback.
