I'm wondering if you can see if the monitor is v2 on the box, i know there are numbers on it but dont know exactly what numbers v2 is.
If anyone know this, please let me know.
See if xl2411z is v2 on the box?
Re: See if xl2411z is v2 on the box?
All 3 of mine had V2 hand written on the white model label.
All purchased from Amazon US.
Bailey
Bailey
PUNCHRULLE
Can you say what the other numbers were? Maybe your monitors were updated by some shoplopsided wrote:All 3 of mine had V2 hand written on the white model label.
Bailey
They were all in original, sealed boxes. Number was handwritten on the manufacturers UPC or model label.
PUNCHRULLE
I mean on the benq box not the shipping box,there should be 2-3 different serial numbers somewhere on it.
Similar thread here:-
http://forums.blurbusters.com/viewtopic.php?f=13&t=1053
if it say
I believe its v2
if it say
Code: Select all
00-121-BA-
PUNCHRULLE
Ok, will look after this number in store,thank yourapt0r wrote:Similar thread here:-
if it sayI believe its v2Code: Select all
00-121-BA
