VG259QM input lag
VG259QM input lag
Hey guys my VG259qm is acting weird. I play fortnite competitively with the lowest settings and no matter how much fps I get I still feel like my mouse movements are really delayed, the only fix I found was to cap my fps at 120, but whats the point of playing 120 fps on a 280hz monitor.. So if anyone has a solution for my problem please help me!
VG259QM (MAIN) | XL2546K | Aorus KD25F
Re: VG259QM input lag
If you uncap your FPS, does your GPU go over 90% load? If yes, then that's a known cause of input lag. NVidia Reflex can mitigate this. But capping your FPS will also result in preventing this GPU load induced input lag.
If you're on an AMD GPU, Radeon Anti-Lag can help somewhat. Not as much as capping your FPS though.
