Z series firmware 2
JesuV
Z series firmware 2
Post by JesuV » 20 Jul 2014, 07:28
Is there coming a step by step introductions for firmware update with linux, or should i buy mstar isp upgrader to upgrage my BenQ XL2411Z? I don't trust my skills, and i don't want to break my monitor. Also is there any information that is there coming way to do it with windows? I havent used linux much, so i am bad at using it.
Re: Z series firmware 2
Post by Chief Blur Buster » 29 Jul 2014, 22:34
JesuV wrote:Is there coming a step by step introductions for firmware update with linux, or should i buy mstar isp upgrader to upgrage my BenQ XL2411Z? I don't trust my skills, and i don't want to break my monitor. Also is there any information that is there coming way to do it with windows? I havent used linux much, so i am bad at using it.
There is currently no easy Linux step by step, as it is very distribution and graphics card dependant.
If you want the easy way to upgrade, it is recommended to use the MSTAR ISP upgrade method.
http://www.blurbusters.com/benq/diy-fir ... -z-series/
kamill
Post by kamill » 30 Jul 2014, 06:29
Just study it without updating firmware. You will learn how to do this.
