DDR4 vs DDR5 Input Lag/Latency
What does the data say on DRR4 vs DDR5 regarding Input Lag/Latency? Should a new build stick with DDR4 or go with DDR5?
Re: DDR4 vs DDR5 Input Lag/Latency
DDR5 has slightly higher Ram Timings, but it will give you a couple of more FPS, so technically DDR5 is be better (lower frametimes, less frametime fluctuations).
But we are talking about sub millisecond differences, not worth the money.
