Will the input lag issue @144hz ever be fixed?
And will we be informed if/when it is?
sheepdog16
Re: Will the input lag issue @144hz ever be fixed?
dmbr wrote:And will we be informed if/when it is?
Lol? Lag? Care to elaborate? I own a G-Sync 144Hz VG248QE monitor, but with no lag @144Hz.
Strangerbob
sheepdog16 wrote:dmbr wrote:And will we be informed if/when it is?
He means what was discovered in this test. http://www.blurbusters.com/gsync/preview2/
Scroll down and examine the graphs and stuff.
I dont know if it will be fixed or whether it can be fixed.
But what i am sure of is that nvidia could fix it easily by implementing a setting in control panel that for gsync monitors has by default an fps cap below the max refresh enough to remove the input lag.
Turboman750
Asus is marketing their G-sync monitors as 144hz 2d and 120hz 3d. The test showed no additional input lag at 120hz but a small amount of increased imput lag at 144hz.Strangerbob wrote:sheepdog16 wrote:dmbr wrote:And will we be informed if/when it is?
As long as your caping your FPS at 120hz in 3d applications you shouldn't experience any additional input lag (from my understanding).
no but it can be improved by one frame at 144hz.
currently 144hz gsync has 2 more frames of lag than capped 140/130/120/whatever gsync
see this thread
http://forums.blurbusters.com/viewtopic.php?f=10&t=895
see this thread
You could always just change the refresh rate to something a tad lower than 144. It won't hurt, I promise.
Sorry, how would that help?
