Integer rounding
Vocaleyes
Integer rounding
Post by Vocaleyes » 23 Feb 2023, 22:54
Would anyone with the know how be able to tell me if this https://support.microsoft.com/en-us/off ... 308e403748 has any place in the current state of mouse handling techniques, or if that’s the wrong thing entirely, essentially looking to see if integer rounding is used in mouse cursor positioning, please and thank you.
Vocaleyes
Re: Integer rounding
Post by Vocaleyes » 24 Feb 2023, 07:07
Looking more into this, touchscreen input seems unaffected by this drifting bug.
So I wonder if it’s due to this;
GMMP_USE_DISPLAY_POINTS 1 - Retrieves the points using the display resolution.
whereas GMMP_USE_HIGH_RESOLUTION_POINTS 2 - Retrieves high resolution points. Points can range from zero to 65,535 (0xFFFF) in both x- and y-coordinates. This is the resolution provided by absolute coordinate pointing devices such as drawing tablets.
Could explain why dpi scaling is hit and miss or in my case why scaling display exacerbates this issue.
How would one check to see if mouse is indeed using gmmp 1 and would it be a good idea/ possible to use 2?
https://learn.microsoft.com/en-gb/windo ... dfrom=MSDN
Vocaleyes
Post by Vocaleyes » 27 Feb 2023, 05:43
Issue was resolved on Mac by switching from integer to floating point.
https://github.com/symless/synergy-core/pull/6469
Merged with another report of my specific drift, up and to the left.
https://github.com/input-leap/input-leap/issues/112
Does windows use int instead of float? And how to change. Thanks.
Vocaleyes
Post by Vocaleyes » 02 Mar 2023, 17:21
This can be closed if needed. It has been confirmed that the drift isn’t due to how the coordinates are being calculated.
Shade7
Post by Shade7 » 02 Mar 2023, 17:30
Vocaleyes wrote:
02 Mar 2023, 17:21
Any info on what the real cause of the drift is?
Vocaleyes
Post by Vocaleyes » 02 Mar 2023, 17:50
Not as of yet, only that the drift is observable through submitted input data. But for the first time in years am hopeful.
Shade7
Post by Shade7 » 03 Mar 2023, 19:07
Vocaleyes wrote:
02 Mar 2023, 17:50
Keep us updated- I'm intereted in finding out.
