Huge tearing lines
WolFy19
Huge tearing lines
Post by WolFy19 » 19 Mar 2023, 15:35
Hi, im gone crazy, hope someone can help me, i have Huge tearing line while gaming. Almost 40% of my screen is a blurry line (at 240fps 240hz with rivatuner)
Ive tested gsync compatible and i can sense some frameskip.
I have a xl2546k and a razer 8khz mouse. Ive tested different polling rate, and refresh rate, if i run uncapped its better but its choppy.
Ive disabled c-states, ive tried different timers, fresh install, some mouse fix all my usb, fixed voltage, underclock, overclock. Nothings change. Thnx in advance
yeesecretalias
Re: Huge tearing lines
Post by yeesecretalias » 19 Mar 2023, 21:49
You might be getting some harsh 0.1% lows and minimums.
That's the first thing I'd check as averages don't tell the full story.
i7-13700k @ 5.7GHz, GeForce RTX™ 3070 GAMING OC 8G (rev. 2.0) - Gigabyte, MSI PRO Z690-A DDR5, 32GB DDR5-6000, Samsung NVMe M.2 980 1TB, Acer Nitro XV252QF @ 390hz, Razer Viper 8k @ 8khz, Artisan Hayate Otsu Soft XL / Artisan Shidenkai, AtlasOS 1803
yeesecretalias#5481 on Discord
WolFy19
Post by WolFy19 » 20 Mar 2023, 04:10
Thnx for ur help, ive found whats my problem was : it was MSI mode, it seems my Z390 aorus pro didnt like my gpu going in msi mode (rtx 2080)
