Been going through some monitors lately and one of the issues i've been having is the oversaturation on the standard profiles since they had a wide gamut. The srgb clamp provided by the monitors in OSD restricted RGB gain options or brightness or other settings which is not great since they would end up having a tint or be too bright or dim.
I've come across this tool called "novideo_srgb" from a reddit post which is mostly useful for nvidia since amd has it already built in the driver controller, link: https://www.reddit.com/r/Monitors/comme ... idia_gpus/
This tool seems to be performing an SRGB clamp based on EDID (Extended Display Identification Data), I don't know what that means honestly, I am an amateur with this stuff but I do wonder if this is an effective tool since it seems to be getting positive feedback.
It would be nice since I had no luck finding services locally that offer display calibration and you can't always find an icc profile. Sadly I've returned the high gamut monitors and it doesn't seem to do much on my low gamut TN. I'm wondering this would be effective for a wide gamut IPS.
SRGB clamp tool
Boomchakadah
Re: SRGB clamp tool
Yes, it's an effective tool that fixes the oversaturated colors of wide-gamut monitors. Your TN monitor doesn't show any changes because it's not a wide-gamut monitor.
VG258QM 280Hz TN (main)| XG2431 240Hz IPS | XL2540K 240Hz TN | XV252Q 1080p 280Hz IPS | XL2546K 1080p 240hz TN | AW2518HF 1080p 240Hz TN | XV240YP 1080p 165Hz IPS | XG2402 1080p 144hz TN | 27GL83A 1440p 144Hz IPS | XL2411P 144Hz TN | XF240H 144Hz TN
Re: SRGB clamp tool
Sorry to necro this thread, but does anyone know if doing this would effect the input lag of the monitor for games at all?
I have the AW2725df QD-OLED and wanted to srgb clamp the wide-gamut color space to fix oversaturation since the dedicated sRGB mode gamma is currently too bright.
