if everything was lowered down, as in the main (highest hz) placed in the center of the screen, as in thats where you are mainly looking/aiming in game
i thought the ULMB on my monitor was not good, but if i make it in the center it looks fine
Would the UFO test be better if
MSIfanboy
- center.png (2.24 MiB) Viewed 3252 times
Re: Would the UFO test be better if
You can center the TestUFO automatically by pressing the “full screen” button inside the TestUFO at the upper-right corner of the animation.
Also, some monitors have low strobe crosstalk at top and bad crosstalk at bottom.
It’s a very monitor-dependent calibration that is based on strobe phase calibration.
On some monitors such as XG2431, it is adjustable, see www.blurbusters.com/xg2431
