make a 2 .bat files
1)
sc config "NVDisplay.ContainerLocalSystem" start=disabled
sc stop NVDisplay.ContainerLocalSystem
2)
sc config "NVDisplay.ContainerLocalSystem" start=auto
sc start NVDisplay.ContainerLocalSystem
it may help with Hard Pagefault and DPC
Simple script to disable NVContainer
olofsson_tom
Re: Simple script to disable NVContainer
What does this break? When is container needed? Do you run this disable every time you start the computer, or is it disabled most of the time and you enable to use Nvidia control panel then disable again or what?
if you disable that after restart it not work and not work in currently run, but you can enable it and it run right now without problem and after restart it work.olofsson_tom wrote: ↑24 May 2023, 04:33What does this break? When is container needed? Do you run this disable every time you start the computer, or is it disabled most of the time and you enable to use Nvidia control panel then disable again or what?![]()
only for nvidia control panel, all driver func is work.
also, im use debloated driver.
NVCleaninstall will or can do this for you + more!
PatheticBot
Nice work, came looking to disable without fully uninstall
