I've been reading you for quite a while now and first I want to say thank you for sharing this really interesting knowledge you have about motion-blur and other "monitor topics".
I came here first for emulation and modern gaming purposes (and kept my CRTs so far) but I now have some questions about movies...
I'm thinking about getting a projector to handle all my movies / TV shows and I would love to know more about the motion-blur effect (and other important points to know if there is) you get with digital projectors.
I read quite some topics about projectors on the web and it seems that some videophiles still prefer "Large three-lens CRT" ones (called Tri-tubes) and I started to wonder if it's because of this motion thing...
There is different problems though with this case:
1- this kind of CRT projectors is really difficult to set-up (it has to be done by a pro during a full day apparently!) and you should better be sure that you will never move out before installing them!
2- they can handle full-hd sources but in no way 24p so you still have to deal with NTSC or PAL "modifications"...
So here it seems that no solution is really perfect.
What I'm wondering then is :
Is it possible to have some kind of "film-style motion" (maybe through 24p shutter at 48 or 72hz?) that kind of recreate the original film experience we used to have with the 180 degree shutter on film projectors?
Also how do they handle this nowadays with digital projectors in the cinemas? It seems that they use the DLP technology, so I guess it is the way to go but I don't know more.
If anyone has more knowledge (not difficult
Thanks in advance.
Nocta
