These new ULMB 2 monitors look amazing. Motion clarity looks great especially with the claims that their clarity looks equivalent to a 1000hz monitor(i know they're only 360hz strobed).
For anyone that's had both monitors can you give perspective on whether the upgrade is worth it? My main game genre is FPS like Apex legends which I have no trouble maintaining 240 to 300 fps with my 3080 / OC'd 10900k as well as other shooters like battlefield, cod and battle bit.
I've had a 360hz ips panel in the past but went back to the DyAc monitor because it felt smoother likely because of DyAc. It was one of the first Alienware 360hz panels. Any help from someone that's seen both would be greatly appreciated. Not sure how the panel would perform if fps dropped to say around 200-240fps(it may drop going from 1080 to 1440p)
The testing i saw from overwatch it was clearly visible even compared to the 360hz DyAc monitor ULMB looked more clear and sharp. Thanks for any help or insight!
Asus ULMB 2 upgrade from Benq XL2546K?
bumbeen
Re: Asus ULMB 2 upgrade from Benq XL2546K?
the crosstalk is jank, strobe phase is way off
