AM5 Socket / 7000 series CPU Discussion
I LOVE TIN FOIL
Im really disliking the current intel prices and was wondering about new Gen AMD, if they are on-par or better than intel input lag wise - or are they plauged by the same issues?
Any timer issues?
Any timer issues?
Re: AM5 Socket / 7000 series CPU Discussion
.. And AMD still doesn't support TSC-Deadline.
for my ingame mouse feel, my 5800x is much better then z690/z790, also amd dont have any problem with timer, all work good by default, but with nvidia gpu gameplay maybe feel like you play 60hz with 360hz monitor, but mouse feel is 100% better on amd.I LOVE TIN FOIL wrote: ↑04 Jul 2023, 18:54Im really disliking the current intel prices and was wondering about new Gen AMD, if they are on-par or better than intel input lag wise - or are they plauged by the same issues?
Any timer issues?
Maybe reason because amd have usb in cpu, idk.
Boomchakadah
https://www.ebay.com/itm/284929644313
https://www.newegg.ca/p/17Z-010M-000E8
I just bought that M.2 to USB 3.0 header adapter so that i can bypass the chipset. I'll see if there is a difference or not.
VG258QM 280Hz TN (main)| XG2431 240Hz IPS | XL2540K 240Hz TN | XV252Q 1080p 280Hz IPS | XL2546K 1080p 240hz TN | AW2518HF 1080p 240Hz TN | XV240YP 1080p 165Hz IPS | XG2402 1080p 144hz TN | 27GL83A 1440p 144Hz IPS | XL2411P 144Hz TN | XF240H 144Hz TN
That's nice! But you need only NEC v2 chip.Boomchakadah wrote: ↑07 Jul 2023, 02:17I just bought this M.2 to USB 3.0 header adapter so that i can bypass the chipset. https://www.newegg.ca/p/17Z-010M-000E8 I'll see if there is a difference or not.
this is best way to connect mice to cpu on intel platform.
Boomchakadah
nec v1 have jitter
New discovery lol. Maybe in apartments with abnormal input lag and desync of the gameplay. This is not required in normal locations. You can look at streamers or pro players. They have everything perfect in a bunch of AMD cpu and nvida gpu.
