Mouse/keyboard connect question
LAGenjoyer666
Post by LAGenjoyer666 » 27 Jul 2023, 04:06
Should i connect my keyboard and mouse to cpu or chipset which one is better for input?
i know which ports belongs where since i have my motherboards manual in front of me so i dont need help with that.
andreeeeee-
Re: Mouse/keyboard connect question
Post by andreeeeee- » 27 Jul 2023, 06:56
I'm gonna tag along your question and ask this: for Intel mobos, is there the same differentiation (CPU handled ports vs MOBO handled ports) in a setup which additional USB hubs are connected to the mobo through the appropriate pins?
I mean, would the native USB ports from the back of an Intel mobo be CPU handled, and USB ports from this additional USB hub (pin connected) be MOBO handled?
ahead
Post by ahead » 27 Jul 2023, 20:41
I know only USB and ps2 options for connecting keyboard/mouse; what are you talking about???
andreeeeee-
Post by andreeeeee- » 31 Jul 2023, 10:20
ahead wrote:
27 Jul 2023, 20:41
Check this video: https://www.youtube.com/watch?v=88IOcFE4yho&t=181s
ahead
Post by ahead » 31 Jul 2023, 22:44
I can't see in your video something other connection sockets for a mouse/keyboard; still only USB or PS2.
Post by Slender » 01 Aug 2023, 23:56
andreeeeee- wrote:
31 Jul 2023, 10:20
ahead wrote:
27 Jul 2023, 20:41
he speaks correctly about the usb port for the mouse. This is great and really reduces the delay completely bypassing the chipset and providing a direct connection between the mouse and the processor (one can only dream of such a thing on Intel), but he did not take into account the fact that all these features are useless if you have a bus between cores and constant jitter on a mouse with a delta of 990hz -1010hz (the minimum I've been able to cut is 995hz-1005hz) with any nvidia gpu, which makes gameplay on a 360hz monitor feel like 144hz, but with incredible responsiveness.
Boomchakadah
Post by Boomchakadah » 03 Aug 2023, 02:32
FYI, all USB ports on Intel go through the Chipset. If you have an 11th gen intel CPU or newer, the primary M.2 slot is connected directly to the CPU. You can use a USB to M.2 adapter in that slot to bypass the chipset. I'm using this one.
https://www.ebay.com/itm/284929644313
https://www.newegg.ca/p/17Z-010M-000E8
I have a 13700K and an MSI Pro Z690-A DDR4
VG258QM 280Hz TN (main)| XG2431 240Hz IPS | XL2540K 240Hz TN | XV252Q 1080p 280Hz IPS | XL2546K 1080p 240hz TN | AW2518HF 1080p 240Hz TN | XV240YP 1080p 165Hz IPS | XG2402 1080p 144hz TN | 27GL83A 1440p 144Hz IPS | XL2411P 144Hz TN | XF240H 144Hz TN
andreeeeee-
Post by andreeeeee- » 05 Aug 2023, 07:06
Boomchakadah wrote:
03 Aug 2023, 02:32
Cool idea, thanks for sharing
LAGenjoyer666
Post by LAGenjoyer666 » 05 Aug 2023, 07:28
I have Ryzen 5900x so i guess i can connect directly to cpu?
andreeeeee-
Post by andreeeeee- » 05 Aug 2023, 07:37
LAGenjoyer666 wrote:
05 Aug 2023, 07:28
Yes
Check this video to see how you can verify which port goes directly to the cpu: https://youtu.be/3fX1157Mm7k
