I use G-Sync + V-Sync + frame cap normally on Windows.
Is V-Sync being forced on Wayland really a problem then? Is V-Sync from the compositor equivalent to enabling V-Sync in NVCP on Windows?
I am trying to figure out if with the upcoming 545 Nvidia driver (when multi-monitor G-Sync will be fixed on Wayland) if it will be equivalant to a Windows experience.
Thanks!
Is forced V-Sync on Wayland really a problem with G-Sync? (Linux)
PacketAuditor
- jorimt
Re: Is forced V-Sync on Wayland really a problem with G-Sync? (Linux)
G-SYNC only uses V-SYNC's VBLANK signal adherence to ensure the tearline is steered offscreen at all times when the framerate is within the refresh rate, regardless of what double buffer method you use, so if Wayland's method is functioning and is of the double buffer variety, it should be fine for use with G-SYNC.PacketAuditor wrote: ↑27 Jul 2023, 09:11Is V-Sync from the compositor equivalent to enabling V-Sync in NVCP on Windows?
PacketAuditor
So if the Wayland compositor (KWin) is using triple buffering it will not provide good latency results? I'm not sure what method it uses or if you can modify it (ChatGPT says triple buffering), or if another compositor might be better (Weston?).jorimt wrote: ↑27 Jul 2023, 09:47G-SYNC only uses V-SYNC's VBLANK signal adherence to ensure the tearline is steered offscreen at all times when the framerate is within the refresh rate, regardless of what double buffer method you use, so if Wayland's method is functioning and is of the double buffer variety, it should be fine for use with G-SYNC.PacketAuditor wrote: ↑27 Jul 2023, 09:11Is V-Sync from the compositor equivalent to enabling V-Sync in NVCP on Windows?
Sorry, I am just starting out with Linux and just want to have an equivalant VRR experience to Windows.
- jorimt
Triple buffer will still work to prevent tearing, but could potentially add extra latency/issues due to its extra buffer (G-SYNC operation is natively double buffer).PacketAuditor wrote: ↑27 Jul 2023, 11:18So if the Wayland compositor (KWin) is using triple buffering it will not provide good latency results?
I have zero Linux experience, so can't help you there.PacketAuditor wrote: ↑27 Jul 2023, 11:18Sorry, I am just starting out with Linux and just want to have an equivalant VRR experience to Windows.
PacketAuditor
Thanks for the info, it's a big help!
Hopefully a Linux user might be able to give me some more insight.
Kyouki
I recently became a massive Linux nerd and on my quest to figure things out on that platform, I have found several resources that say kwin/kde plasma in general has the option now to disable and allow tearing to occur (thus no vsync) though, there is more to the story found here:PacketAuditor wrote: ↑27 Jul 2023, 09:11I use G-Sync + V-Sync + frame cap normally on Windows.
Thanks!
https://zamundaaa.github.io/wayland/202 ... yland.html
As proven here:
https://invent.kde.org/plasma/kwin/-/merge_requests/927
and I can see this option within my Arch build with KDE Plasma/kwin.
So no, not anymore. I mostly played on a laptop from work to mess around with things within the OS and found it barely to affect me as a latency sensitive person in general.
PacketAuditor
I do want V-Sync so that I can use G-Sync "as intended" and according to the blurbusters guide (G-Sync + V-Sync + frame cap).Kyouki wrote: ↑27 Jul 2023, 11:47I recently became a massive Linux nerd and on my quest to figure things out on that platform, I have found several resources that say kwin/kde plasma in general has the option now to disable and allow tearing to occur (thus no vsync) though, there is more to the story found here:
As proven here:
Do you know if the KWin V-Sync + G-Sync will function the same as NVCP V-Sync + G-Sync in Windows? And if not, can I just disable V-Sync in the compositor like you said is now possible, and then enable V-Sync in NVCP on Linux to achieve the optimal configuration?
THANKS! <3
Kyouki
Not using Nvidia card to tell you that, sorry. Laptop is equipped with AMD APU.PacketAuditor wrote: ↑27 Jul 2023, 11:52I do want V-Sync so that I can use G-Sync "as intended" and according to the blurbusters guide (G-Sync + V-Sync + frame cap).Kyouki wrote: ↑27 Jul 2023, 11:47I recently became a massive Linux nerd and on my quest to figure things out on that platform, I have found several resources that say kwin/kde plasma in general has the option now to disable and allow tearing to occur (thus no vsync) though, there is more to the story found here:
As proven here:
THANKS! <3
But i'd guess so, yes since the mechanics are in the display mode + telling the display what to do.
I don't know though.
