				Is forced V-Sync on Wayland really a problem with G-Sync? (Linux)
				Posted: 27 Jul 2023, 09:11
				by PacketAuditor
				I use G-Sync + V-Sync + frame cap normally on Windows.
Is V-Sync being forced on Wayland really a problem then? Is V-Sync from the compositor equivalent to enabling V-Sync in NVCP on Windows?
I am trying to figure out if with the upcoming 545 Nvidia driver (when multi-monitor G-Sync will be fixed on Wayland) if it will be equivalant to a Windows experience.
Thanks!
				Re: Is forced V-Sync on Wayland really a problem with G-Sync? (Linux)
				Posted: 27 Jul 2023, 09:47
				by jorimt
				PacketAuditor wrote: ↑27 Jul 2023, 09:11
G-SYNC only uses V-SYNC's VBLANK signal adherence to ensure the tearline is steered offscreen at all times when the framerate is within the refresh rate, regardless of what double buffer method you use, so if Wayland's method is functioning and is of the double buffer variety, it should be fine for use with G-SYNC.
				Posted: 27 Jul 2023, 11:18
				by PacketAuditor
				jorimt wrote: ↑27 Jul 2023, 09:47
So if the Wayland compositor (KWin) is using triple buffering it will not provide good latency results? I'm not sure what method it uses or if you can modify it (ChatGPT says triple buffering), or if another compositor might be better (Weston?).
Sorry, I am just starting out with Linux and just want to have an equivalant VRR experience to Windows.
				Posted: 27 Jul 2023, 11:24
				by jorimt
				PacketAuditor wrote: ↑27 Jul 2023, 11:18
Triple buffer will still work to prevent tearing, but could potentially add extra latency/issues due to its extra buffer (G-SYNC operation is natively double buffer).
I have zero Linux experience, so can't help you there.
				Posted: 27 Jul 2023, 11:26
				by PacketAuditor
				jorimt wrote: ↑27 Jul 2023, 11:24
Thanks for the info, it's a big help!
Hopefully a Linux user might be able to give me some more insight.
				Posted: 27 Jul 2023, 11:47
				by Kyouki
Thanks!
I recently became a massive Linux nerd and on my quest to figure things out on that platform, I have found several resources that say kwin/kde plasma in general has the option now to disable and allow tearing to occur (thus no vsync) though, there is more to the story found here:
https://zamundaaa.github.io/wayland/202 ... yland.html
As proven here:
https://invent.kde.org/plasma/kwin/-/merge_requests/927
and I can see this option within my Arch build with KDE Plasma/kwin.
So no, not anymore. I mostly played on a laptop from work to mess around with things within the OS and found it barely to affect me as a latency sensitive person in general.
				Posted: 27 Jul 2023, 11:52
				by PacketAuditor
				Kyouki wrote: ↑27 Jul 2023, 11:47
As proven here:
I do want V-Sync so that I can use G-Sync "as intended" and according to the blurbusters guide (G-Sync + V-Sync + frame cap).
Do you know if the KWin V-Sync + G-Sync will function the same as NVCP V-Sync + G-Sync in Windows? And if not, can I just disable V-Sync in the compositor like you said is now possible, and then enable V-Sync in NVCP on Linux to achieve the optimal configuration?
THANKS! <3
				Posted: 28 Jul 2023, 07:10
				by Kyouki
				PacketAuditor wrote: ↑27 Jul 2023, 11:52
As proven here:
THANKS! <3
Not using Nvidia card to tell you that, sorry. Laptop is equipped with AMD APU.
But i'd guess so, yes since the mechanics are in the display mode + telling the display what to do.
I don't know though.
