Looking for a new monitor and some advice
CrunchyBiscuit
Post by CrunchyBiscuit » 12 Aug 2023, 09:41
Hey there!
I'd like to buy a new monitor (mostly for gaming and browsing). Which one of these four monitors would you recommend, and why?
AOC 24" VA panel, 1920x1080 @ 165Hz (Freesync Premium)
https://aoc.com/us/gaming/products/monitors/24g2sae-bk
AOC 24" IPS panel, 1920x1080 @ 165Hz (Freesync Premium)
https://aoc.com/us/gaming/products/monitors/24g2spae-bk
BENQ 24" VA panel, 1920x1080 @ 165Hz (Freesync Premium)
https://www.benq.com/en-us/monitor/gaming/ex240n.html
BENQ 24" IPS panel, 1920x1080 @ 165Hz (Freesync Premium)
https://www.benq.com/en-us/monitor/gaming/ex240.html
The only absolute requirement that I have is that the monitor should be able to handle a static refresh rate of 125Hz through CRU or the NVIDIA control panel (looking for advice on reliable timings from experienced people, preferably from those who have used these monitors). Also, it would be cool if it supports 1:1 pixel non-native aspect ratios without scaling/stretching (most monitors do, but not all of them, and the NVIDIA control panel sometimes can't help out either).
Thanks in advance!
Sirius
Re: Looking for a new monitor and some advice
Post by Sirius » 12 Aug 2023, 22:25
Don't take VA panel if you don't want bad black smearing and bad ghosting performance.
You can also have smearing when you scroll on text with some VA panel.
I recommend you the Mobiuz IPS one, better OSD than AOC but maybe the motion clarity will be better on the AOC IPS.
Current temporary test : none | Main monitor : Acer XV272UX | I had : 1080P : XL2546X / XL2566K / XL2546K / XL2546 / XL2540K / XL2746S / EX2510 / MAG251RX / NXG253R / MAG271CR / VG259QM / VG258QM / XG249CM / XG259CM / VG279QM / S2522HG / XG2431 / XG2405 / XG2702 / AW2518HF / AW2521HF / AW2720HF / 24G2U / Omen X 25 | 1440P : XV272UX / MAG274QRF-QD / MSI MAG 274QRF-QD E2 / 27GP850 / 27GN850 / AW2723DF / Omen X 27 / XG27AQM / XG27AQMR / S2721DGFA / Odyssey G7 / EX270QM / VG27AQML1A / XENEON 27QHD240 / XV272UKF / XV272UX 4K : U28G2XU2 / M32UC
CrunchyBiscuit
Post by CrunchyBiscuit » 13 Aug 2023, 07:32
Okay, so no VA. Gotcha. Thanks.
