Can't enable fullscreen exclusive mode
I used to have it enabled, then I switched from HDMI to USB-C/DP (I have a legion 5) and it stopped working, even If I switch back to HDMI it won't work...
I followed every possible guide online, I am using Windows 11 22621.2134
Re: Can't enable fullscreen exclusive mode
Is this with every game you play or a specific game? Can u name a example of a game? ( if its Apex u need to alter the registry. I can send a yt how to do this)WalterWhiteHimself wrote: ↑15 Aug 2023, 07:41I used to have it enabled, then I switched from HDMI to USB-C/DP (I have a legion 5) and it stopped working, even If I switch back to HDMI it won't work...
| Now:
| Past: XL2586X 540Hz/PG248QP/271QRX/VG259QM with the Qisda panel/PG27AQN/XL2566K
Every game I play, I know the registry thing I already did it.
Kirby OS windows 11 has a enable fullscreen exclusive mode button for whole Windows. If that mode exists a disable full-screen exclusive mode for whole Windows should also exist. Seems u activated the latter somehow. My advice is reinstall Windows 11 or in Install KirBY OS win 11 so you can use that switch. Kirby OS is a great gaming build. Very light with great gaming sound. ( don't use it for work though)WalterWhiteHimself wrote: ↑15 Aug 2023, 10:31Every game I play, I know the registry thing I already did it.
| Now:
daviddave1 wrote: ↑15 Aug 2023, 14:28
I assume it sets GameDVR_FSEBehavior to 2, I already did that
Your assumption does not sound logical. It's a fact your full-screen exclusive mode is disabled for your whole Windows. If the only setting that can make this happen is gamedvr_fsebehavior your problem should already be solved.
| Now:
Or maybe another setting overwrites itdaviddave1 wrote: ↑15 Aug 2023, 16:27Your assumption does not sound logical. It's a fact your full-screen exclusive mode is disabled for your whole Windows. If the only setting that can make this happen is gamedvr_fsebehavior your problem should already be solved.
EDIT : I was right, I got rid of GameDVR_FSEBehaviorMode and it worked
Yes that's exactly what I am saying: your logic was flawd. So you where wrong. But np glad I could help in fixing the problem with your PC! (And not your way in thinking offiously.)WalterWhiteHimself wrote: ↑15 Aug 2023, 17:49Or maybe another setting overwrites itdaviddave1 wrote: ↑15 Aug 2023, 16:27Your assumption does not sound logical. It's a fact your full-screen exclusive mode is disabled for your whole Windows. If the only setting that can make this happen is gamedvr_fsebehavior your problem should already be solved.
EDIT : I was right, I got rid of GameDVR_FSEBehaviorMode and it worked![]()
| Now:
