Specific eletromagnetic time zone INPUT LAG FIX (00000000.1%)
Supercutx
**THIS IS PROB JUST PLACEBO BUT WILL WORK ONLY FOR 00000000.1% PEOPLE HAVING THIS SPECIFIC ELETROMAGNETIC INTERFERENCE BUT YOU CAN TRY IF YOU WANT**
**SRY FOR ANY ENGLISH MISTAKES, NOT NATIVE.**
--- Eletromagnetic specific fix for more snappy mouse movement (will be placebo for almost everyone) ---
Go to Start > Settings > Time & language > Date & time
First turn off the option that sets automatically the time.
Change time zone to (UTC+09:00)Seul (your pc and mouse will sync with the eletromagnetic field of SOUTH KOREA time zone) I've test every UTC and this has the least interference in mouse movement but you can try others.
Now go down to Time & Language > Region
Under Country or region, select your new region.
Here is ranked the best countries i've tested and includes the ones that have most CSGO high ranks players according to afkgaming.com
ECOADOR β’β’β’β’β’ (can be different for you but this is the best that worked for less mouse interference)
TAIWAN β’β’β’β’
UNITED KINGDOM β’β’β’
SOMALIA β’β’β’
ESTONIA β’β’β’β’β’
RAE DE HONG KONG β’β’β’β’
FINLAND β’β’β’β’
DENMARK β’β’β’β’
Note: I do not play csgo but instead very high rank LOL (gm-challenger) and champs that requires very fast exact pixel pointing which allows me to tell if mouse movement changes.
---BIOS---
The core of the system resonating on certain letters will also impact on eletromagnetic interference.
Now go to BIOS and change the idiom to KOREAN, DON'T ASK ME WHY, just do it.
You can try other idiom if you want, to see which has the least interference in your mouse, at the end of the day, it just changes BIOS idiom and you're not using BIOS when playing.
U T S R Q P O N M L K J I H G F E D C B A
That's it, this worked for me and i'm sure IT'S NOT placebo (IN MY CASE).
Feel free to criticize.
TAIWAN β’β’β’β’
SOMALIA β’β’β’
ESTONIA β’β’β’β’β’
FINLAND β’β’β’β’
DENMARK β’β’β’β’
---BIOS---
Kipperii
Re: Specific eletromagnetic time zone INPUT LAG FIX (00000000.1%)
I have done similar things before, (keep changing the time server to test the hitreg)
ahead
Bios idiom? what is it?
MegaMelmek
In win 11 is not:
is that on 10 7 XP?
is that on 10 7 XP?
assombrosso
I notice something big with this, not placebo
Supercutx
Supercutx
It's in windows 11! Just look it up for"time and language" on start menuMegaMelmek wrote: β26 Aug 2023, 07:24In win 11 is not:
is that on 10 7 XP?
Works in win10
triplese
After applying this fix got +3km in my pinus size. Cannot undo
ahead
Change language to help you decrease input lag???? Ok, I am left.
I LOVE TIN FOIL
"yeah bro, if you change the time on your computer, it will sync over the internet the electromagnetic field of the server and fix your lag bro. Trust me bro i took my meds this morning"
