Tweak for you to try [Doesn't Work]
Foul Play
Post by Foul Play » 10 Oct 2023, 19:58
Doesn't work, don't bother
Code: Select all
Hi, I'm autistic and new to the forums, so sorry if this is a bad post.
I think I found a possible audio bug(s) in Windows 10 and 11 which could be the main issue for heavy mouse, input delay and high DPC.
This is my workaround for this problem.
[b]1) download Microsoft Interrupt Affinity Tool from TechPowerUp
2) run the software as admin
3) Delete Mask for every audio device listed no matter what and ONLY THEM (e.g. Audio Endpoint, High Definition Audio Device , NVIDIA High Definition Audio, USB Audio Device, etc.)
[i]There will be errors but you can ignore them[/i]
4) do a restart of the computer (Recommended) or restart the device when asked[/b]
That's it and I hope this helps people.
System:
5800X3D
32GB @ 3600 CL16-16-16-16-38
RTX A4000
980 Pro NVMe 2TB SSD
Windows 10
rekaa02511
Re: Tweak for you to try
Post by rekaa02511 » 11 Oct 2023, 10:50
I did this like a week ago but for all devices and it helped a lot. Made my "floaty" mouse more accurate in cs2
MIETAS
Post by MIETAS » 12 Oct 2023, 05:39
makes 0 sense since they have no masks by default.
Might do SOMETHING when you've tweaked affinities before and stuff went wrong.
KingAzar
Post by KingAzar » 12 Oct 2023, 17:48
MIETAS wrote:
12 Oct 2023, 05:39
I was about to say the same thing, I double-checked and there is nothing assigned by default. Something must have been pre set on his computer.
