Hi there,
Am planning to buy ATI Radeon 5450 HD 2GB graphic card to play quaklive on 144hz monitor, am just asking if this low end graphic card support Dual link DVI cable. Am plannig to buy a 144hz monbitor which is Asus VG 248QE and I was wondering if the 5450HD can work with this monitor?
if this card doesn't support Dual link DVI which cheap graphic card does?
thank you
Does Radeon 5450 HD 2GB support Dual link DVI?
Re: Does Radeon 5450 HD 2GB support Dual link DVI?
All 5000-series Radeon's are capable of dual-link DVI.
In addition to the ASUS VG248QE, another good monitor to consider is the BENQ XL2411Z.
