Motion blur reduction black screen [fixed]
Posted: 20 Aug 2014, 23:49
I have recently purchased a XL2411Z and I have just received it today. Everything went perfectly fine and I was enjoying toying with my monitor for the day.
It all started when I reset the settings to factory default, I toyed with a few things and all of the sudden the screen went completely black. I restarted my computer and everything worked from the bios to the login screen and it went black once again.
I fixed everything from then and dvi works again, I think there was an issue where when motion reduction is on it darkens the screen very heavily and then suddenly it is completely black like before. I can now run my new monitor without motion blur reduction but this is not what I want to do, I also want to use the strobe utility. Whenever I try to turn blur reduction on it gives me the same black screen, any way to fix this? I tried to use strobe utility without the reduction on because it doesn't work and the utility does not work as well anymore for me.
Thank you for your input.
