LG 27” 1440P 480Hz OLED CES 2024
Dalek
Re: LG 27” 1440P 480Hz OLED CES 2024
Post by Dalek » 05 Jan 2024, 10:11
Cool, here's to hoping they eventually release a 24" OLED panel.
kameCS
Post by kameCS » 06 Jan 2024, 02:05
my next monitor will have these specs, 1440p is really comfortable but requires a higher configuration, later Asus may offer a version with a 25" 1300p mode
edit : asus pg27aqdp 480hz is officially announced
current: PG27AQN 360Hz
before: AW2524HF | PG248QP | AW2523HF | PG27AQDM | XL2566K | XV252QF | XG27AQM | VG259QM | 34GL750
jetcat3
Post by jetcat3 » 06 Jan 2024, 10:04
It’s glossy and up to 275 nits with 100% APL! At 50 seconds here.
evmadic
Post by evmadic » 09 Jan 2024, 05:45
If it has dp2.1 I'm in.
Unfortunately at the moment, the only one "rumored" to have it is the new HP oled
5800x3d, RTX 4070 ti, Acer Nitro XV252QF 390Hz
https://www.twitch.tv/evmadic
forcedreg
Post by forcedreg » 09 Jan 2024, 17:55
Here's the asus model using the LG panel. According to this guy it's glossy, has BFI (only up to 120 hz, but maybe even 240 or higher, not confirmed) and comes out H2 2024.
https://www.youtube.com/watch?v=lFRc8b1yQEA
TFTcentral corroborates a lot of this stuff, article here:
https://tftcentral.co.uk/news/asus-rog- ... l-unveiled
evmadic wrote:
09 Jan 2024, 05:45
from the tft article
tftcentral wrote:It’s possible Asus are still investigating whether DP 2.1 could be added to the 27″ 480Hz and 32″ 4K 240Hz models, although as we reported in our recent article, this is difficult and challenging at this time. More details to be confirmed later on.
By the way, what are the benefits of using DP 2.1?
evmadic
Post by evmadic » 10 Jan 2024, 04:50
forcedreg wrote:
09 Jan 2024, 17:55
You avoid use of Display Stream Compression that becomes active once you exceed DisplayPort 1.4's bandwidth limitation of 32gb.
People say that they don't notice a difference but most monitors out right now that operate using DSC don't exceed the limitation by too much. There was a youtuber who did an in-depth review of the LG 27GR95QE, in it he tested DP1.4 and then HDMI 2.1 (48gb) and said he felt the difference. My suspicion is that the more a display exceeds the bandwidth limitation and relies on DSC, the worse things will feel.
ericl
Post by ericl » 10 Jan 2024, 18:40
I just saw a video of someone walking by and looking at the Asus 480hz OLED.... and it was running blurbuster's UFO test.
SOMEONE TAKE A PURSUIT VIDEO OF IT, I want to see how well 480hz OLED performs with the UFO test.
Boop
Post by Boop » 12 Jan 2024, 01:17
ericl wrote:
10 Jan 2024, 18:40
https://twitter.com/BlurBusters/status/ ... 3560645688
The Chief took one. Check the Blur Busters twitter account.
ericl
Post by ericl » 12 Jan 2024, 11:04
Yeah, I just saw it and came here.
Looks pretty dang good. The map one where you can read the small little text was impressive. It was a bit more difficult to discern the eyes on the UFO test though.
