Desync in all games with new cat 8
I'm going to tell you about an experience I had yesterday, I bought some white CAT 8 network cables since the ones I have are black and to make them look neater in my white room I wanted to change them, each cable is 1M from the modem to the router and from the router to the PC, I put the new good quality CAT 8 cables, I enter the game and I notice something strange... Like the enemies saw me before and I say mmm strange, it's probably my internet or something else, I leave the I enter another game and the same thing, so I promise what I thought about was the cables, I took them out, put the previous ones in and the problem was solved... I tried it 3 times and the change was instantaneous in all the games... Conclusion even though it may seem like a lie The brand or quality of the network cables you have can make a very big difference in the games, especially if you have those problems where you can't react to the enemy or something like that... Actually in my case I left the previous cables since the difference is very big.
PD: i am use traslator.
Re: Desync in all games with new cat 8
Model of the old one ?
Yeah would like to know what your old one is. Also the make of your new one then compare
When you plug the old cable back in does it fix the issue?ZINZIRIO wrote: ↑13 Jan 2024, 20:41I'm going to tell you about an experience I had yesterday, I bought some white CAT 8 network cables since the ones I have are black and to make them look neater in my white room I wanted to change them, each cable is 1M from the modem to the router and from the router to the PC, I put the new good quality CAT 8 cables, I enter the game and I notice something strange... Like the enemies saw me before and I say mmm strange, it's probably my internet or something else, I leave the I enter another game and the same thing, so I promise what I thought about was the cables, I took them out, put the previous ones in and the problem was solved... I tried it 3 times and the change was instantaneous in all the games... Conclusion even though it may seem like a lie The brand or quality of the network cables you have can make a very big difference in the games, especially if you have those problems where you can't react to the enemy or something like that... Actually in my case I left the previous cables since the difference is very big.
Yes, the difference is Instant in all games, I tried it 3 times to make sure and the difference is very noticeable
Sorry which one is the "old" one?ZINZIRIO wrote: ↑15 Jan 2024, 09:01Before: https://www.ebay.com/itm/325257420882?m ... media=COPY
After: https://www.ebay.com/itm/353099689026?m ... media=COPY
MisterS0L0
I mean it's interesting that its made a difference, even if its a negative one.
But surely you just send the new one back and use the old one ? No ?
Yes exactly, I will continue using the old one, the truth is that I am a little surprised that two network cables affect the performance of a game so much.
