VT trick + bbr off ?
TenkuLo
hi,its my first post in this nice forum
i got benq 2411z and i want to know if vt trick work with bbr off?if yes whats the pros and cons?i have few other questions.. to disable VT trick i must delete the custon resolution on toasty cru and restart pc?is possible the 1350 trick 120hz without using toasty pixel clock patcher?
Falkentyne
Re: VT trick + bbr off ?
No point in the VT tweak if blur reduction is off.
VT tweak is for the strobing to give the screen more time for refreshes (to reduce the strobe crosstalk band area).
This doesn't mean anything if strobing is off, although it could theoretically very slightly change overdrive RTA artifacts (no one has tested that though).
The VT tweaks run the monitor to the limit of specifications, though, so you may see some faint 'banding' (similar to what the VG248QE and XL2411T sometimes experienced, although far less noticeable) when using the VT tweaks. Other than that, if you need them for BBR on, might as well just keep using it, or use 144 hz if you don't.
