240 Hz ULMB 1 vs 360 Hz
DeaxSeax
Post by DeaxSeax » 16 Jan 2024, 20:28
Which one is better in terms of performance?
Re: 240 Hz ULMB 1 vs 360 Hz
Post by RealNC » 17 Jan 2024, 13:28
DeaxSeax wrote:
16 Jan 2024, 20:28
It doesn't affect performance.
O-T-T
Post by O-T-T » 17 Jan 2024, 14:21
DeaxSeax wrote:
16 Jan 2024, 20:28
I'm not an expert at all, so take my words with a grain of salt but:
ULMB often worked poorly so I assume you want to consider ULMB 2 and/or the new Pulsar tech (basically a renamed ULMB 2), in which case, for what I read, 240hz (on a decent panel) +ULMB 2/Pulsar should be vastly superior to a "plain" 360hz monitor (without BFI/ULMB/etc.). If ULMB 2/Pulsar works like BFI, then I believe that on 240hz panel you should get a 75% blur reduction and therefore perform roughly like a theoretical 750hz panel...but I could be completely wrong, If you want to get accurate numbers you better ask an expert member of the forum or the Chief :D
Post by RealNC » 17 Jan 2024, 14:29
O-T-T wrote:
17 Jan 2024, 14:21
That is correct. But it doesn't affect performance. These things have no impact on frame rates.
O-T-T
Post by O-T-T » 17 Jan 2024, 14:38
RealNC wrote:
17 Jan 2024, 14:29
O-T-T wrote:
17 Jan 2024, 14:21
I know ;) But I think what he was asking was quite understandable... on the other hand on this forum we talk almost exclusively about motion clarity and blur reduction, so I interpreted his word "performance" in this sense.
HumanAI_004
Post by HumanAI_004 » 29 Jan 2024, 07:49
As the others noted the topic question is ambiguous.
I own an ULMB1 monitor myself (PG279Q, IPS) (waiting for new ASUS PULSAR display this year so badly…). The backlight pulse (ON) time is 2ms at 120Hz and 100% pulse width setting. This equals a pixel persistence of 2ms. A 360Hz monitor has a frame time roughly of 2.8ms. And on a sample and hold display this equals 3ms of persistence. So in terms of motion blur the ULMB1 should be better if looking on the numbers only.
BUT:
I am playing mainly with ULMB enabled (Warthunder) because without, the motion blur is not acceptable for me. I am very sensitive to motion blur unfortunately.
But ULMB1 has some disadvantages which lower the overall “performance”:
*stuttering even when Vsync on and fps are fixed to 120Hz (most annoying for me because reason unknown).
*multiple strobe images in the top and bottom region of the monitor (this is acceptable in my game because in motion I look at the central part of monitor only).
*much darker because backlight is in average much lower intensity. (acceptable by reducing ambient light)
*colors are worse (acceptable when gaming)
If my RTX3080 would deliver >360Hz I would prefer 360Hz FPS over ULMB1 120FPS.
Kyouki
Post by Kyouki » 30 Jan 2024, 06:30
I've got the AW2521H and also a sensitivity for blur from displays (as well as games's TAA) and I use 240hz ULMB at times for competitive games but frequently am fine on playing 360hz adaptive sync technology.
Works pretty good for my use cases.
