VSync on or off with Gsync
Shooty76
Post by Shooty76 » 28 Aug 2014, 10:51
Hi,
i got today my new Asus ROG Swift Monitor. Most of the time i play League of Legends. Do i have to turn off Vsync or do i have to turn it on or doens't it matter what i do with Vsync?
Thanks for help
Chris
Re: VSync on or off with Gsync
Post by RealNC » 28 Aug 2014, 11:12
In order to activate gsync you have to enable it in the nvidia control panel. When you do that, it will disable vsync even if it's enabled in the in-game settings.
However, the safest way is to also disable vsync in the in-game settings, since there might be cases where a game has other settings tied to its vsync setting. Although this might be paranoia, you never know...
Shooty76
Post by Shooty76 » 28 Aug 2014, 13:46
Ah thanks
