Lowest input lag usb card for mouse / keyboard
i deactivated all the usb except the front 3.0 usb and im using for keyboard and mouse at 2k Hz both.
and im looking for the best Card to plug my mouse and keyboard with lowest input lag Possible!!
Thanks
my pc specs is
Asus strix z270f motherboard
i7 7700k
16Gb 3200Mhz
samsung evo plus 250gb
Corsair 860i
Razer Viper v2 Pro 8k
Corsair K65 mini 8k
25' alienware 360hz
25' alienware second screen 240hz
Case Lian li Pc-011 Dynamic.
Thanks
my pc specs is
i7 7700k
16Gb 3200Mhz
Corsair 860i
Corsair K65 mini 8k
25' alienware 360hz
Re: Lowest input lag usb card for mouse / keyboard
Your mobo has PS2 port , buy a ps2 keyboard for better mouse movementrooy wrote: ↑02 Feb 2024, 08:18i deactivated all the usb except the front 3.0 usb and im using for keyboard and mouse at 2k Hz both.
Thanks
my pc specs is
i7 7700k
16Gb 3200Mhz
Corsair 860i
Corsair K65 mini 8k
25' alienware 360hz
Use 2.0 ports for mouse
Your board has Intel v219 nic , 3 different z270 with v219 I tried all sucked before disabling and using external ethernet card
Testi it if you want: You will observe better with cpu intensive high fps games , but even elden ring vs you should be able to tell
Also ehci was millions times better than xhci , but for external usb controllers , idk
Yea, not sure where these strange people came from that think plugging in a mouse on USB 3.0 ports feels better. Doesn't matter if it's z77, z87, z170, or z590, the 2.0 ports are always better for me. Yes, if you want to run a meme mouse with 1 billion hz polling rate then the 3.0 ports might be more stable, but those people are probably where all the "why do I have constant tearing and stutter" posts on this forum come from.
[phpbb-automod-form: r0ach, please see forum rules, especially the NO POLITICS forum rule.]
2.0 definitely feels better to me, feels slightly more sharp/precise, shame most newer boards have done away with them
It’s one of the biggest issues moving forward with lots of things.
Style > substance & functionality. Not just PC’s but a majority of day to day things.
Also 2.0 is de wai.
Yea, it’s pretty easy to tell a difference even though both ports go to the same USB 3.2 controller, but the pin out is different. I haven’t been paying much attention to newer 8k meme mice (even though I have a Viper 8k I don’t use). Anyone know if any mice with USB 3 pin out actually exist?
- IMG_0302.png (28.63 KiB) Viewed 11589 times
i dont have usb 2.0 in my motherboard. also no usb 2.0 in my case . Lian li 011 Dynamicr0ach wrote: ↑03 Feb 2024, 08:17Yea, it’s pretty easy to tell a difference even though both ports go to the same USB 3.2 controller, but the pin out is different. I haven’t been paying much attention to newer 8k meme mice (even though I have a Viper 8k I don’t use). Anyone know if any mice with USB 3 pin out actually exist?
I got same mobo (Z270F) but how can i know which 2.0 usb ports are there? Cant find anything onlineamorou wrote: ↑02 Feb 2024, 11:53Your mobo has PS2 port , buy a ps2 keyboard for better mouse movementrooy wrote: ↑02 Feb 2024, 08:18i deactivated all the usb except the front 3.0 usb and im using for keyboard and mouse at 2k Hz both.
Thanks
my pc specs is
i7 7700k
16Gb 3200Mhz
Corsair 860i
Corsair K65 mini 8k
25' alienware 360hz
And: which are ehci ports? Sorry for my english
Your mobos backpanel seems lack usb2.0 , specs says only asmedia controller has usb 2.0 , they prolly front panel jacks on moboskkiNN wrote: ↑07 Feb 2024, 08:03I got same mobo (Z270F) but how can i know which 2.0 usb ports are there? Cant find anything onlineamorou wrote: ↑02 Feb 2024, 11:53Your mobo has PS2 port , buy a ps2 keyboard for better mouse movementrooy wrote: ↑02 Feb 2024, 08:18i deactivated all the usb except the front 3.0 usb and im using for keyboard and mouse at 2k Hz both.
Thanks
my pc specs is
i7 7700k
16Gb 3200Mhz
Corsair 860i
Corsair K65 mini 8k
25' alienware 360hz
Asmedia might suck try if you want
ehci was a usb controller and it was on older boards , genius mobo manufacturers dont include them anymore
Does your bios has hpet option ? Most of the asus mobos dont have it
If yes disable it
If not mod your bios and disable it
If money is not a problem , switch to z97-77 since your are not too far away IPC wise
no one usb 3.0 mouse there.r0ach wrote: ↑03 Feb 2024, 08:17Yea, it’s pretty easy to tell a difference even though both ports go to the same USB 3.2 controller, but the pin out is different. I haven’t been paying much attention to newer 8k meme mice (even though I have a Viper 8k I don’t use). Anyone know if any mice with USB 3 pin out actually exist?
usb 1.1 - 1000hz max (fullspeed)
usb 2.0 - 2000hz + (high speed)
some 1000hz wireless mouse use 2.0.
for imitation echi usb 2.0 u can buy external pci-e mcs9990
