Is BB Strobe Utility disconnected??
I hope there is an update for Dyac2 monitors.
https://blurbusters.com/benq/strobe-utility/
Any chance to get BB Strobe Utility update for Dyac 2?
rrisk93
Supermodel_Evelynn
Re: Any chance to get BB Strobe Utility update for Dyac 2?
that would make the DYAC 2 monitors perfect if that were to happen
But as BenQ said they don't care.
Anonymous703819
They never said that.Supermodel_Evelynn wrote: ↑17 Apr 2024, 10:04that would make the DYAC 2 monitors perfect if that were to happen
ciwesa
Hi. I just joined. Is there any information about the new update?
You can edit BlurBustersStrobeUtility.ini to add support for additional DyAc monitors.
Or press "F" and try Profile A or Profile B in the BenQ version of Strobe Utility.
C:\Program Files\Blur Busters\ is where your specific strobe utility is installed at.
All strobe utilities are hackable (BenQ Strobe Utility, ViewSonic strobe utility, etc) by editing their INI configuration files to add custom VCP codes.
Please paste your edits for specific BenQ monitors.
