andreeeeee-
Re: Heads up for people with AMD gpus
Interesting.
Did you disable it in the playback devices list after keeping it enabled in device manager?
I kept it enabled but it turned out to be placebo once again. Even though I tested it on and off for a bit it lost effect like most other things. Placebo but you can try.
I LOVE TIN FOIL
AMD gpus are known to have great input latency honestly at least for me.
What you should you do is strip the audio driver from the package completely before installing the GPU driver.
Not having it installed = no placebo issues.
