Hi  I run Parsec on an Acer nitro 5 laptop, Its an ok base level gaming laptop.
I was thinking of upgrading to a Desktop with Monitor. I'm concerned there'd be latency added compared to my laptop.
Am I being stupid and what would be Very good choices for that set up.
Thanks
						Best kind of setup up for Parsec ?
Re: Best kind of setup up for Parsec ?
dont buy PC bro!Rob23 wrote: ↑26 Apr 2024, 09:08Hi I run Parsec on an Acer nitro 5 laptop, Its an ok base level gaming laptop.
Thanks
what you need to perfect:
good gaming laptop + monitor
and battery station for charge your lap + powerON monitor.
if you use lan you can try find "rj45 emi filter" or like that.
that is better way for avoid all bad things...
Ok cool  Thanks man for the reply
