s1mple sucks now because of this
babooz99
Post by babooz99 » 23 May 2024, 02:04
i bet simple caught the desync/electricity bug in csgo2, hes super bad now. You can see it his reaction time looks really slow (probably desync from what he sees on his monitor screen and actual game) and enemies insta one tap him. He takes 30 bullets to kill an enemy with his spray. He used to hit easy shots in csgo because he didnt have desync in csgo. Now he will be finished by this bug
delve
Re: s1mple sucks now because of this
Post by delve » 23 May 2024, 08:54
I have seen some clips, he 100% has the desync issue at least from time to time.
cursed-gamer
Post by cursed-gamer » 23 May 2024, 10:42
I wish I could have his desync. Maybe finally I would make 3k elo.
widow13
Post by widow13 » 23 May 2024, 11:44
cursed-gamer wrote: ↑
23 May 2024, 10:42
Well desync won't render you useless but will limit your potential by a lot.
cursed-gamer
Post by cursed-gamer » 23 May 2024, 13:30
widow13 wrote: ↑
23 May 2024, 11:44
23 May 2024, 10:42
I know this by looking at what I do on good days.
2kmules
Post by 2kmules » 24 May 2024, 04:21
I heard that he has had input lag as of the past year, and I checked out some clips in CS2 on his end and it looks like classical symptoms of dirty electricity/EMI. The hitreg looks incredibly slow/chunky and delayed. In good electrical conditions the hitreg should be fast, and buttery smooth. I actually suspect that this type of desync/delay is caused mainly by the monitor, router and modem's performance being degraded by dirty AC rather than the computer itself. The PSU's in computers have strong enough capacitors to mitigate EMI to enough of a degree but those other components are much worse at that.
His current ISP might also be sub-par, if I were to guess, but that is just speculation.
Post by RealNC » 24 May 2024, 06:00
Or maybe he's just getting older and thus naturally slower.
"Reaction times do slow with age. Physical changes in nerve fibers slow the speed of conduction as one ages."
https://www.urmc.rochester.edu/encyclop ... tentID=562
Steam β€’ GitHub β€’ Stack Overflow
ahead
Post by ahead » 24 May 2024, 06:04
RealNC wrote: ↑
24 May 2024, 06:00
+1
widow13
Post by widow13 » 24 May 2024, 07:18
RealNC wrote: ↑
24 May 2024, 06:00
He also had a big break and doesn't like/enjoy cs2 that much so it's only natural his performance has gotten worse.
agstrato
Post by agstrato » 24 May 2024, 11:31
It's clear that he has the same issue as we do. He still kills a lot because he is good at this but we can all see the same stuttering all over. And now he also has lower ping which is another disadvantage so yeah you are absolutely right. He got old? sure but not that old and either way he played and plays a lot which keeps muscle memory going strong so please unless he's like 40+ don't start with this.
