I have just recently learned of screen overclocking.
I have successfully run at 1920x1080@120hz using CRU. I've done the frame skipping test and it passed.
I should also mention this is an AMD card 7900 series
Windows 8.1
No audio? I will keep trying, I have imported the .dat file.
does not appear to be inserting the block as notated by the single * instead of **
but will show ** for bitstream not hdmi audio basic.
The restart64.exe will not revert audio, but will revert video.
update;
I fixed the audio problem for now
I uninstalled my drivers (AMD)
I used DDU to wipe out any problems
Re installed drivers (14.4)
Reran CRU this time i made sure the audio.dat was selected the first time
and now it works
VIZIO E3D470VX [Successful 1080p @ 120Hz]
Re: VIZIO E3D470VX [Successful 1080p @ 120Hz]
Excellent to hear you have done a successful 1080p overclock to 120Hz!
