do i have this correct in regards to gysnc
Posted: 10 Sep 2024, 09:22
getting a 4070 ti need some advice
using these settings on a another card
do i leave setting as they are which as as follows
gysnc enabled
use the frame limter in nvidia control panel with inside monitors refresh rate of 144hz currently have it set to 140hz (global limit)
all ingame litmters set to unlimted (thinking that unlimted means there is no in game limiter)
prefered refresh highest available
got this advice from a video on youtube i can edit and post if you wish
gysnc enabled
