I've been having this issue now for a few years and its driving me crazy. Let me describe the symptoms first. From day to day, boot to boot, the mouse input feels different and not as responsive as it should be. It's not mouse lag though, it appears to be more like the mouse is deviating in how far it moves based on how far/fast you moved it and changing directions makes it feel like the mouse has the mass of a house brick so my cursor is more waving left and right rather than responding snappily.
It ruins aiming in fps games. It ends up with me not being able to get my crosshair on target, undershooting, overshooting every time, swinging the mouse left and right when trying to track targets because I'm constantly overshooting or not being able to get the mouse to catch up. When I have my crosshair just off an enemy and need to make a micro correction the mouse doesn't seem to move enough, which make me try to move it a little quicker and then it overshoots.....it's so damn annoying.
Nothing seems to fix it. I've had the issue for years over multiple high end builds. Current specs are:
X670 GAMING X AX 7950x
7900xtx
Patriot Viper 32gb 6000mt RAM
Alienware AW2725DF QD-OLED 360hz 1440p
It's not a display issue as it's the same on all displays I've tried. Currently running a 3 display setup with the alienware, an asus tuf 240hz and a huion kamvas 24 screen tablet doubling up as an extra monitor.
Visually, when I move the mouse quickly on the desktop so you can see the ghosts of the cursor it looks like the cursor is broken up with gaps. I know gaps are normal but it's as if the cursor is displaying in bursts or groups. At 500hz which I'm using right now I'd expect to see the mouse trails across the screen like so...
Code: Select all
. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .Code: Select all
Here are some graphs from mouse tester 1.53.
Interval Vs Time
Frequency Vs Time
X And Y Velocity Vs Time
X And Y Count Vs Time
These tests are done at 500hz. Can anyone who understands these graphs better than me explain what's happening here? To me it looks like I have a base update interval of 8ms with 4ms dips followed directly by 2ms spikes? At 500hz shouldn't it be around 2ms baseline with sub-ms deviation either way and at 1000hz 1ms baseline with sub-ms deviation either way?
Also looks to me like I have a baseline of 500hz polling with weird spikes between 8 and 16khz and spikes in velocity between 20 and 40%? Am I reading the graphs right/am I assuming right with what is expected?
I've tried everything. Windows reinstallation(which was done again recently), every combination of bios settings you can think of including changing hidden bios settings. System timer settings, although I can only change this is windows, I don't have any HPET setting in my bios, even hidden. All power saving options disabled across the board both in windows and bios. Bit sum performance power plan, all drivers system wide are updated to the latest, windows is fully up to date, no malware. I've done literally everything and this issue won't go away. I only have this mouse for the time being but I've had these issues across many mice and systems for years. I've done mouse tester tests on other mice and systems and had similar results and have always noticed the gaps in the mouse cursor and the inconsistent mouse movement. Different DPIs and polling rates just tighten the inconsistencies, not remove them. I've tried every USB port and with all other USB devices unhooked. Latency Mon shows no issues. I have no input lag, the mouse is snappy and responsive for initial movements, it just doesn't feel like it's doing what it's meant to be doing over time. I have all acceleration off. EPP, driver, game, used mark c mouse fix, zeroed out SmoothMouseX/Y in reg settings. Below is a shot of my reg settings.
As I said from day to day the mouse feels different and there is no way to be consistent or even build any muscle memory with it. Some days when gaming it's as if my sensitivity has gone up because the mouse feels floatier/swingier but the sensitivity hasn't actually changed and general distances covered by the the mouse hasn't changed. It feels more like my mouse inputs have inertia or something, but no input delay. On rare occasions, without changing anything, the mouse feels crisp and perfect, but that is very rare and it always goes back to feeling like crap either within minutes, days, sometimes a week or two, but it always goes back.
This is driving me crazy, does anyone have any ideas or suggestions?
