XG2431 Alternatives in 2024?
Necrophag1st
Post by Necrophag1st » 14 Sep 2024, 23:25
Hey all,
I'm currently looking for a new monitor to replace my XG2431. It has served me well, but has unfortunately developed horizontal scanlines across the entire panel. Thankfully, they're somewhat faint and pretty easy to ignore for now, but that tells me the display is probably on its way out. I'm outside of the warranty period also.
I haven't paid any attention to the monitor industry since buying this monitor. All the options available now are a bit overwhelming, especially with OLED on the scene. However, I'm struggling to find anything that seems like a good replacement for the XG2431. I strongly prefer 1080p 24 inch monitors over anything else. I play a mixture of games, anything from extremely fast competitive arena fps (Quake and similar titles) to more modern military style shooters like COD/Warzone/DMZ.
I've been extremely happy with the XG2431's performance and motion clarity, especially because I exclusively play in a dark room with a lamp facing the wall behind the monitor. I don't need a super bright display, but things like input lag, response time, and motion clarity are very important to me. I also love that it's an IPS panel for the superior colors and viewing angles over TN.
Basically, I'm asking if there's anything available (or on the horizon) that dethrones this thing within my criteria or if I should just buy another one.
Thanks in advance!
kyube
Re: XG2431 Alternatives in 2024?
Post by kyube » 15 Sep 2024, 08:15
Necrophag1st wrote:
14 Sep 2024, 23:25
-snip-
If you're looking for the best strobed experience possible apart from the XG2431, then definitely go for the XL2566K.
It can do strobing without any crosstalk in the 100-240hz range and you can use the Blurbusters strobing utility with it, allowing for fine granular control.
I haven't seen whether XL2566X+ (new 400hz panel) can rival it yet, so I'll refrain from recommending it.
Hope this helps.
Falkentyne
Post by Falkentyne » 16 Sep 2024, 23:00
Yep, XG272 OLED can only strobe at most 4.2ms persistance at 60hz, which is the same as 240hz native, and while that is still miles better than regular 60hz, the loss of brightness makes things very rough. Maybe eventually this will change.
tong
Post by tong » 21 Sep 2024, 13:26
kyube wrote:
16 Sep 2024, 17:24
OLED BFI can only go as low as the max refresh rate, hence it is useless for emulating CRT-like motion clarity.
Then he should consider the Asus 480hz OLED, it has BFI at 120hz and 240hz.
Falkentyne wrote:
16 Sep 2024, 23:00
Same drawback as the XG2431, and everyone who used this display (including me) knows in practice the best blur reduction for 60hz will be around 4.2ms persistence. No one was using 1ms persistence @60hz on this monitor.
kyube
Post by kyube » 21 Sep 2024, 13:50
tong wrote:
21 Sep 2024, 13:26
The PG27AQDP cannot reach the MPRT that the XG2431 can during strobing.
Source: @Discorz
108 nits @ 0.8ms MPRT in 60-165hz crosstalk-less range (great for retro) vs ~200nits @ 240hz mode (~2ms MPRT) && 120hz (~4.17ms MPRT)
Quite a stark difference in clarity, if you ask me.
BFI also adds display lag, as per TFTCentral review:
With ELMB / BFI enabled and the screen running at 240Hz we measured around 4 – 5ms of lag, so it’s a little higher in that mode.
I'd argue the XG2431 and XL2566K are the best strobed display experience post-CRT era, up to date. At least from the thoroughly tested displays.
No information on 1440p LCD models (such as the Q24G2A or MAG274QRF-QD)
i_apocalypseon
Post by i_apocalypseon » 21 Sep 2024, 14:37
Im curious. Did the apparently low contrast ratio not bother you?
Supermodel_Evelynn
Post by Supermodel_Evelynn » 22 Sep 2024, 20:20
We have some positive news with regards to the BenQ monitor with DYAC
Since those monitors cannot do 60HZ strobe for console games, fighting games, retro games etc
AMD has AFMF 2 which is driver based frame generation you get double FPS in any game so 120 FPS for fighting games, it adds 10ms lag which cannot really be detected by 99.9% of humans anyways.
AFMF 2 is the best frame generation technology that currently exists and unlike DLSS Frame Generation which is limited to a handful of select games, AFMF 2 will work on anything, so this means you can take advantage of the ZOwie monitors DYAC modes
Lossless_Scaling exists but requires significantly more GPU power than AFMF 2 and has higher input delay "5ms"
tong
Post by tong » 27 Sep 2024, 08:38
kyube wrote:
21 Sep 2024, 13:50
Maybe, but everything else is better and the clarity is close enough. Not to mention it's not an unreliable POS:
https://www.amazon.com/ViewSonic-XG2431 ... merReviews
