fLayN wrote: ↑22 Sep 2024, 17:06
#1 - 240FPS / 480HZ = Lowest input lag
Yes.
#2 - 240 FPS / 240HZ BFi ON = Best clarity
Yes.
#3 - 240 FPS / 240HZ BFi OFF (reducing the native Hz of the 480hz monitor) = better clarity but more input lag than #1 - worse clarity but butter input lag than #2
Same clarity as #1. No benefits to it over 480Hz if you use VRR. If you don't use VRR and want 240Hz vsync, you can still get that at 480Hz if you're on an Nvidia GPU by setting 1/2 vsync in nvidia profile inspector. You can choose between normal vsync (syncs to 480Hz,) 1/2 vsync (syncs to 240Hz), 1/3 vsync (160Hz sync) and 1/4 vsync (120Hz sync.) 480Hz with 1/4 vsync for example (to get 120FPS/120Hz sync) has quite a bit lower input lag than running at 120Hz mode with normal vsync.
But 480Hz with VRR is the absolute best when it comes to input lag, if the game you're playing doesn't result in too much OLED VRR flicker. Also note that if you use 480Hz, then no matter what FPS cap you use, when VRR matches the screen Hz to the game's FPS, it does so with QFT. So display lag will always be the minimum possible.
