FreeSync question
Posted: 26 Sep 2024, 03:14
Hello,
I have a Legion 5-15ACH6H. I have hybrid mode enabled, and my screen set to 60 Hz. The AMD software tells me that the FreeSync range of my monitor is 60 to 60. Is there any point in using FreeSync when the screen is set to 60 Hz? It seems that FreeSync only works when the screen is set to 120 and the FPS is between 60 and 120, but I'm not sure how it works exactly, so I came here to get a better explanation on how to use it properly for my laptop.
When using FreeSync, should I limit FPS to a little below the screen refresh rate, enable VSync, or both?
Hope that someone can give me some advice. Thanks in advance!
