Can someone help me with this?
ZINZIRIO
Post by ZINZIRIO » 26 Oct 2024, 00:19
Hello, I have had an entry delay for about 2 years which I have not been able to solve permanently... But there is something I am doing that solves it for 1 day and then I repeat the solution and again, like this every day it comes back to me. work well but I don't know what it could be that I have to repeat "The solution" to be able to play. The point is this... I have a modem, router, UPS and voltage regulator... My PC connected directly to my house's power but the modem and router every time I change it between my house's power, UPS and voltage regulator solve all my problems, what do I want to tell you with this? Is it that today, for example, I use the modem and router in the UPS, tomorrow with the regulator and then directly to the power in my house, so every day it solves the problem that could be happening? Dirty energy or something? But why does it solve every time I connect it to something different? It's strange isn't it? I await opinions... Thank you very much
ZINZIRIO
Re: Can someone help me with this?
Post by ZINZIRIO » 26 Oct 2024, 00:44
I can add something like every time I change the circuit for a different one, be it UPS or regulator, an electrical reset occurs in the modem and router and that solves the problem instantly... Every time I do it it works perfectly. One thing I also thought is that both the modem and the router have two legs, maybe if I could ground it somehow it would solve the problems.
themagic
Post by themagic » 26 Oct 2024, 04:53
ZINZIRIO wrote: ↑
26 Oct 2024, 00:44
Easy...there exist adapter like this which comes with ground and are for routers (that what it says) too and many other devices stuff...
Example here ones for EU...
https://www.amazon.de/Einstellbarer-Net ... tdGY&psc=1
https://www.amazon.de/Einstellbares-Net ... V4dA&psc=1
or most easy sulution get grounding strip and do it yourself and attach it to router and to chassis of grounded device...
https://www.google.de/search?q=groundin ... client=img
https://support.hpe.com/techhub/eginfol ... 320521.htm
or try a combination of both...the adapter + grouding strip.
here some interesting solution too..."a usb-to-ground adapter, and plug it into the router’s usb port"
https://www.jrseco.com/faqs/the-routers ... -big-deal/
Z3CrosS
Post by Z3CrosS » 26 Oct 2024, 05:17
I think that i don't think
themagic
Post by themagic » 26 Oct 2024, 05:56
https://rtkemfprotection.com/en/shieldi ... -plug-usb/
here this one probably gonna help... :D
ZINZIRIO
Post by ZINZIRIO » 29 Oct 2024, 14:13
I bought an adapter with ground but it was again a matter of time before it malfunctioned again... The other idea that occurs to me is to put a car battery + a 12V to 220V converter and try that way at least I know that the problem seems to be in the internet hardware and not in my PC
ZINZIRIO
Post by ZINZIRIO » 29 Oct 2024, 14:15
Z3CrosS wrote: ↑
26 Oct 2024, 05:17
No, Its not an electricity. With power loss you are resetting hardware brain / caches etc. Same happens with damaged PCs, if you dissamble all, cmos reset, put off battery, and after start it and you install fresh windows, around a day, in most cases PC will start to work almost like ideal (not near almost but let this word be), i mean it feels like fresh. But after, with few restarts, it will hit same bad level.
Its signalising of hardware faults with ram-controllers / caches. Performance degradation - thats called.
P.s There is a small possibility, that its Adjustable Power Adapter which uses your lan device, these like Themagic's provided links. If you change device adapter and same symptoms exists, its hardware.
But what causes us to have to reset the cache of the fiber optic modem, for example, so that it works well again?
themagic
Post by themagic » 29 Oct 2024, 15:10
ZINZIRIO wrote: ↑
29 Oct 2024, 14:15
Z3CrosS wrote: ↑
26 Oct 2024, 05:17
good question...many noticed that pull out DSL/Router cable or reconnect or restart the router...and randomly it gives some improvements but only like 1-2 match and don't stays this stable good for the next matches but i know this experience here very well too and saw this with my eyes...without touching even my PC...but the Match which i had after was just pure Advantage for me and in my Favor...
but at same time exist guys who noticed that some fresh windoof install gives some perfect matches but then it all goes again to shitt after some gameplay hours...and the guys who has knowledge they can tell and feel and see this all very fast.
its crazy and no matter at what direction you look at...if electricity or internet...but it's real and the improvements are real and many can see and notice that very fast...that the thing what is it all about and why all the INPUT LAG topics started and many start to talk about this at some forums and noticed that there Online Gaming Not more so Alright stable like it was some Months ago and was working better from Match to Match in the old days...that the difference many notice who get this Issue and don't matter at what Rank they are Today now....
but who to blame at the end and what is the issue exact of everyone ? hardware ? internet providers ? electricity inteference ? only devil knows what that shit is about...
I know only that even higher rank or elo players experience at some point the same shit (if they are matchmaking against same guys with same conditions...what ever this is...maybe ping ? maybe faster packets ? maybe better sync and connect to servers and better peering due to providers services?)...and that the funny thing about all this online fairplay 128 tick experience gaming is today.
But keep Training guys...Aim Lab matters and Game Sense which will don't work when your Online Gaming is fucked up and your Natural Muscle Memory and even your Brain Plays don't RLY gonna help more when this Issue gonna hit You one day or when You Realize that you had this shit experience from Day 1 but still don't understand what and how...
There exist 3 Sorts of Input Lag people...
1 which are had this from day 1 but they don't even question or even try to understand what is wrong...and believing that it is just skill issues or pings...
2. people who had everything fine and was happy with what they had...but one day everything changed to bad and they noticed this bad things and the disadvantage...
3. the ones who had it always alright and worked perfect and no matter what and even today they still fine and enjoying playing online and they see no problems at all and they think that all others just having some skill or aim issue...
but even those 3rd people experience the same shit at some point and that why smurfs exist and more... they can just create a new account and can feel the many nice amount of KILLS and ACES again...feels nice...i agree.
ZINZIRIO
Post by ZINZIRIO » 29 Oct 2024, 18:18
In my case I didn't have the problem until I changed from ADSL to Fiber Optic... A friend told me that with ADSL I didn't have the problem since it is electricity and being electric it is not as vulnerable to interference or something like that... In this case you tell me that it lasts a couple of games but for me it lasts practically a whole day every time I do that... Now I connected the router and the modem again to a different outlet away from the PC and again the problems occurred. They solved it... it's very strange but the problem is there, the worst of all is that when I "solve it" the game works too well for me... Excellent I would say that's why the problem and not being able to fix it once and for all
themagic
Post by themagic » 29 Oct 2024, 18:31
ZINZIRIO wrote: ↑
29 Oct 2024, 18:18
Where you from ZINZIRIO ?
