Has anyone tried succesfully to overclock any OLED monitors? I have a 360hz QDOLED that I run for most of the time at native 1440p res 360hz, but when I play CS2 I play at 768p. So I thought, if those dual mode OLEDs are reaching 480hz at 1080p, could I not get any kind of OC at 768p?
Well seems like I can't lol. At first I tried 1280x720p 390hz and I got an "out of range" message from the monitor's OSD. Then I decided to try 720p 361hz just to see if the monitor had some hard caps that prevented any kind of OC. This time something pretty strange happened: the screen turned fully green, after a second switched to blue, then red, then black and then it just repeated. I got a bit scared (since I got my monitor off craigslist and it's got no warranty) and I pressed escape to revert to 360hz.
I did this with DSC disabled since I read DSC can mess with custom resolutions. Then I tried it with DSC on and same thing happened. Oh well.
Any thoughts?
OLED Monitor overclocking?
Jump to
- The Main Lobby
- ↳ General — Displays, Graphics & More
- ↳ News / Rumors / Conventions
- ↳ Input Lag / Display Lag / Network Lag
- ↳ Display Comfort — Eyestrain / Headaches / Motionsick
- Everything Better Than 60Hz™
- ↳ Eliminating Motion Blur — BFI / ULMB / ELMB / DyAc / framegen / LSS / etc
- ↳ OLED Displays
- ↳ G-SYNC
- ↳ FreeSync
- ↳ Game Consoles — XBOX and PlayStation — ONE / Series S / Series X / PS5
- ↳ BENQ Zowie Tweaking — Strobe Utility / Blur Reduction / DyAc
- ↳ Display Overclocking
- The Laboratory: Display Science Section
- ↳ Test UFO Motion Tests
- ↳ Area 51: Display Science, Research & Engineering
- ↳ Software Developers / Low-Lag Code / Game Programming
- ↳ Pursuit Camera Testing of Display Motion Blur
- ↳ High Frame Rate Video (HFR, UltraHFR, 120fps, 240fps, 1000fps)
- The Cafeteria
- ↳ Offtopic Lounge
- ↳ Niche Issues Affecting Latency — Electrical, Interference, EMI, Unexpected Causes, etc.
- ↳ Forum System / Registration / Suggestions
