Lag on all PC's completely fixed for 5 days
Lagsadok
Post by Lagsadok » 02 Nov 2024, 23:40
I am someone that believes the problem is caused from the body, idk how and it makes no sense, anyways I posted recently asking if anyone has tried using all wireless peripherals. I couldn't find anyone in the forum had mentioned trying it and didn't really get any feedback so I thought I will try it myself.
I used an old mouse, got a new headset and keyboard. To put it simply, now everything just plays perfectly. CS, League and VAL. I have reached the highest rank in all 3 games so I know how the games are supposed to feel when played. It has been 5 days since I tried this and I'm fairly certain it's gone for good, I will update if it comes back if people are hesitant to try this.
I cannot believe I did not try it earlier, granted I didn't think of it was coming from the body until earlier this year.
If any of you also experience issues no matter what PC you use or location you're in, I suggest trying this also, as it is a fairly inexpensive way to hopefully resolve your issues. Good luck :D
I play with the receivers off the desk (might cause slightly slowed inputs) and on the monitor stand, idk if it matters but that's what is working for me, I really hope this is able to help someone else as it was horrible to go through this for years myself.
Also I do not use the PC when charging all the peripherals.
Peripherals im using:
Mouse: Razer Viper v3 Hyperspeed
Keyboard: Keychron v5 Max
Headset: Logitech G733
cursed-gamer
Re: Lag on all PC's completely fixed for 5 days
Post by cursed-gamer » 03 Nov 2024, 07:54
Ask somebody to play around with your PC for few hours. You will become even more convinced of this.
Post by Slender » 03 Nov 2024, 08:12
monitor need be wireless too
widow13
Post by widow13 » 03 Nov 2024, 08:22
Slender wrote:
03 Nov 2024, 08:12
He said he thinks the body is the problem of the situation.
You don't touch your monitor when you play, so basically no.
PuzzledLag
Post by PuzzledLag » 03 Nov 2024, 17:54
Very very interesting. Because touching my monitor sometimes absolutely completely changes my gameplay and smoothness of visuals. Literally just a touch while i have the controller in my other hand, super weird.
I’m also convinced it’s our body. I’ve been reading a lot about grounding our bodies properly and feel like it may have something to do with that
I’ll be home later tonight and try with all wireless peripherals
Lagsadok
Post by Lagsadok » 03 Nov 2024, 18:14
cursed-gamer wrote:
03 Nov 2024, 07:54
Yep, that is one of the main reasons that made me believe that it was the body.
n1zoo
Post by n1zoo » 03 Nov 2024, 19:15
5 days is not a very long time, tell me after a few weeks if the effect is still there.
PuzzledLag
Post by PuzzledLag » 03 Nov 2024, 20:00
I just realized u said u got a brand new headset..
A lot of people have this experience of buying some new hardware and it works for a bit so they swear it’s a fix. There’s a thousand different *fixes* they never last too long.
Give it a week or so more and get back to us because i had the same experience w my brand new wireless headset. Gameplay was buttery smooth for a week or 2 and slowly the bs set back in.
Lagsadok
Post by Lagsadok » 03 Nov 2024, 21:51
PuzzledLag wrote:
03 Nov 2024, 20:00
Completely agree that has happened to me too, but usually only lasts hours and doesn't feel this good. Since all wireless peripherals it is just 24/7 perfect, and I will keep updating on it.
When you got a wireless headset was your keyboard and mouse wired?
PuzzledLag
Post by PuzzledLag » 04 Nov 2024, 01:49
Im currently playing on Xbox. Yes i have everything not wired rn and it’s not making much of a difference. So it’s definitely not a 100% fix
But as i said before when i first purchased my wireless headset i could’ve swore that’s what the problem was. Had flawless gameplay for several days
Nevertheless continue to play and let us know
