Page 1 of 4
Lag on all PC's completely fixed for 5 days
Posted: 02 Nov 2024, 23:40
by Lagsadok
I am someone that believes the problem is caused from the body, idk how and it makes no sense, anyways I posted recently asking if anyone has tried using all wireless peripherals. I couldn't find anyone in the forum had mentioned trying it and didn't really get any feedback so I thought I will try it myself.
I used an old mouse, got a new headset and keyboard. To put it simply, now everything just plays perfectly. CS, League and VAL. I have reached the highest rank in all 3 games so I know how the games are supposed to feel when played. It has been 5 days since I tried this and I'm fairly certain it's gone for good, I will update if it comes back if people are hesitant to try this.
I cannot believe I did not try it earlier, granted I didn't think of it was coming from the body until earlier this year.
If any of you also experience issues no matter what PC you use or location you're in, I suggest trying this also, as it is a fairly inexpensive way to hopefully resolve your issues. Good luck :D
I play with the receivers off the desk (might cause slightly slowed inputs) and on the monitor stand, idk if it matters but that's what is working for me, I really hope this is able to help someone else as it was horrible to go through this for years myself.
Also I do not use the PC when charging all the peripherals.
Peripherals im using:
Mouse: Razer Viper v3 Hyperspeed
Keyboard: Keychron v5 Max
Headset: Logitech G733
Re: Lag on all PC's completely fixed for 5 days
Posted: 03 Nov 2024, 07:54
by cursed-gamer
Ask somebody to play around with your PC for few hours. You will become even more convinced of this.
Posted: 03 Nov 2024, 08:12
by Slender
monitor need be wireless too
Posted: 03 Nov 2024, 08:22
by widow13
Slender wrote:
03 Nov 2024, 08:12
He said he thinks the body is the problem of the situation.
You don't touch your monitor when you play, so basically no.
Posted: 03 Nov 2024, 17:54
by PuzzledLag
Very very interesting. Because touching my monitor sometimes absolutely completely changes my gameplay and smoothness of visuals. Literally just a touch while i have the controller in my other hand, super weird.
I’m also convinced it’s our body. I’ve been reading a lot about grounding our bodies properly and feel like it may have something to do with that
I’ll be home later tonight and try with all wireless peripherals
Posted: 03 Nov 2024, 18:14
by Lagsadok
cursed-gamer wrote:
03 Nov 2024, 07:54
Yep, that is one of the main reasons that made me believe that it was the body.
Posted: 03 Nov 2024, 19:15
by n1zoo
5 days is not a very long time, tell me after a few weeks if the effect is still there.
Posted: 03 Nov 2024, 20:00
by PuzzledLag
I just realized u said u got a brand new headset..
A lot of people have this experience of buying some new hardware and it works for a bit so they swear it’s a fix. There’s a thousand different *fixes* they never last too long.
Give it a week or so more and get back to us because i had the same experience w my brand new wireless headset. Gameplay was buttery smooth for a week or 2 and slowly the bs set back in.
Posted: 03 Nov 2024, 21:51
by Lagsadok
PuzzledLag wrote:
03 Nov 2024, 20:00
Completely agree that has happened to me too, but usually only lasts hours and doesn't feel this good. Since all wireless peripherals it is just 24/7 perfect, and I will keep updating on it.
When you got a wireless headset was your keyboard and mouse wired?
Posted: 04 Nov 2024, 01:49
by PuzzledLag
Im currently playing on Xbox. Yes i have everything not wired rn and it’s not making much of a difference. So it’s definitely not a 100% fix
But as i said before when i first purchased my wireless headset i could’ve swore that’s what the problem was. Had flawless gameplay for several days
Nevertheless continue to play and let us know
