High Polling Mice and Keyboards, what USB Lanes are you using?
Alpha
Post by Alpha » 16 Dec 2024, 12:56
Hoping for some discussion and observations regarding what lanes everyone is using for their high polling peripherals.
I run 8000hz mice and keyboard. My input options are,
CPU
Chipset
RTS5420
The motherboard manual has a diagram pointing to the chipset.
Anyone tested? Any pros and cons, latency, frametime, or otherwise? Best practice or does it matter?
Hyote
Re: High Polling Mice and Keyboards, what USB Lanes are you using?
Post by Hyote » 16 Dec 2024, 13:28
USB 2.0 directly to the CPU, things like XHCI Hand-Off and every hidden BIOS setting regarding USB 3 is off as well. I don't notice any inconsistency, just better latency after testing every port one by one.
