Resolution Question
Kanipshun
Resolution Question
Post by Kanipshun » 18 Dec 2024, 04:34
Does anyone know why I am able to create these custom resolutions on a 2560x1440 display?
I cannot choose any of them in Nvidia CP but I can in windows display settings. DRS factors are off and have been and I can confirm that game ini files are showing resolution of 2930x1630 (which was as high as I could go).
Is this using DSC? The resolution does not look any different and seems to have no impact on performance.
Re: Resolution Question
Post by Slender » 26 Dec 2024, 08:42
Kanipshun wrote: ↑
18 Dec 2024, 04:34
use cru.exe and sre.exe
Kanipshun
Post by Kanipshun » 26 Dec 2024, 23:21
Yes I use both but what I cannot understand is how I can create a resolution greater than my monitor display. I understand how DSR works but somehow I am able to use the higher resolutions in windows display, it's not using DSC or DSR.
Post by RealNC » 27 Dec 2024, 15:14
Kanipshun wrote: ↑
26 Dec 2024, 23:21
You can create whatever resolution you want. But whether or not the display will actually accept the resolution is a completely different matter. Some displays will accept higher than native res and downscale them. My 240Hz 1440p display for example accepts 4K input at 60Hz.
